Activity › Forums › Adobe Premiere Pro › No Sound In Premiere Pro
  • Greg Joyce
    January 30, 2012 at 2:42 am
    I am having this problem and none of the solutions here have worked.
    Specifically, sound will play in the timeline fine, but if I double-click a clip to load it into the Source monitor, it’s silent. The waveform is there, for both tracks, but no sound plays. If I select the Audio Mixer tab, the sound plays, but that seems to be playing from the timeline.
    There is NO SOUND from the source monitor.
    What is going on here?
  • Caleb Mclaughlin
    February 14, 2013 at 2:22 pm
    Same here. I see activity in the audio levels monitor, but no sound through my system. If I open a clip in Audition, I can hear it. All other system audio plays through whichever device I tell it to through windows. The problem lies in Premiere, and I’ve been all over the preferences, cleared them, etc. to no avail. Next up is a reinstall unless one of you can talk me out of it.
    Caleb
  • Tom Camuso
    March 29, 2013 at 7:21 pm
    So kinda simple fix for me. I found out that my premiere pro had no .cfa file of the .wmv that had no sound displayed. So I just made a copy of the original .wmv on my desktop and renamed it. Sound’s back. I thought to check this because it was a problem I had a while ago when I was trying to save on a storage drive. Seems like Premiere has problems with instance names.
    Go to search on your computer and look up ‘media cache files’ as a folder. Find the name of your project and check to see if your .cfa is listed.
  • Ivan Myles
    March 29, 2013 at 7:31 pm
    Try: Edit > Preferences > Audio Hardware and check the Default Device.
    The computer’s sound application will show which output is receiving the audio signal, also.
  • Jam Goku
    October 4, 2014 at 2:09 pm
    For those who still having this no sound problem in Premiere pro. I myself found one cause and a solution. If you have K-lite or maybe same app, uninstall it. I signed in to creative cow just now, just to share this to all of you. hope it works to some with the same case.
  • Jonathan Degueldre
    December 2, 2014 at 6:58 am
    I have experienced the same problem but this solution totally worked for me, thank you so much!!
  • Kamil Wawrzyszko
    June 24, 2016 at 3:28 pm
    Interesting. I am on PP CC 2015.3 and simply renaming the video file allowed PP to see the audio in the file again. No I need to figure out why I can’t see any video any more in those files (I can see video in some old projects). An issue with the latest PP caching or conforming?
    Kamil
  • Kasongo Mukama
    October 3, 2020 at 3:03 pm
    Thanks David this really works ,I’ve tried it and succeeded
Page 2 of 2
