Activity Forums Adobe After Effects No Sound from Wav file in After Effects ? HELP !!
  • No Sound from Wav file in After Effects ? HELP !!
    Posted by Ben Matt on November 23, 2008 at 4:45 am
    I know working with sound in After Effects is not the best option. I have Sonar Producer that I will use. However, I wanted to do a test to see how my project times with my music. I imported a small wave file into my project. It shows, appears right and everything, but there is no sound ? Do I have to turn something on somewhere ?
    Please help 🙂
    Ben Matt replied 17 years, 9 months ago 2 Members · 2 Replies
  • Steve Johnson
    November 23, 2008 at 6:57 am
    Do you have the sound layer enabled? (speaker box beside layer name on the left) If so, do you have audio export enabled in your render settings? If you get sound in your ram preview, then you should focus your efforts on the render settings. Audio is not enabled by default for the render queue. Goto output settings and make sure Audio is checked.
    CS3 – Mac
    C4D
  • Ben Matt
    November 24, 2008 at 7:39 pm
    Thanks all. I have got it to work
