Activity Forums Avid Media Composer No serial control from Express HD
  • No serial control from Express HD
    Posted by Tom John on May 12, 2005 at 12:09 am
    Hello, all,
    I am endeavoring to help set up an Avid Express HD system on a nicely-equipped Dell PC.
    However the Avid isn’t talking to the nearby UVW-1800 Beta deck. Checked deck configuration and can see nothing obviously wrong. The serial cable is fine, also. (And the Avid controls a DV device just fine.)
    Any suggestions?
    Tom
    DesertVideo@earthlink.net
    Tom John replied 21 years, 3 months ago 4 Members · 6 Replies
  • Joe Womble
    May 12, 2005 at 2:11 am
    Are you using a Rosetta stone or data Mate serial to 422 converter? Are the lights working on it?
    If so, have you gone into deck configuration and used auto-configure correctly?
    Regards,
    Cre8tive
  • Tom John
    May 12, 2005 at 3:40 pm
    Negative on Rosetta, etc. Are any external adaptors/components required for controlling a Beta SP machine from Express HD? I don’t recall needing one for Avid Express Pro. (Presently I am just connecting from the PC serial port to the deck.)
    Tom
  • Vpcmike
    May 12, 2005 at 4:24 pm
    All computer serial ports are RS-232. All Sony tape decks are RS-422. You need an adaptor (such as a Rosetta Stone) to translate 232 to 422 so that the machines will talk to each other.
  • Bill Stephan
    The serial ports on the PC are RS232 protocol and the remote ports on VTRs are RS422 protocol. You can’t connect them together and expect them to work. That’s why you need a protocol converter like the Rosetta Stone to connect them.
    Bill Stephan
    Senior Editor/DVD Author
    USA Studios
    New York City
  • Tom John
    May 12, 2005 at 6:08 pm
    Thanks for the feedback, guys!
    Best,
    Tom
  • Tom John
    May 12, 2005 at 8:00 pm
    We have ordered an RS-422 adaptor. However, just a follow-up question for safety:
    Upon starting Avid Express HD, I am getting the following prompt: “Com 1 is busy and cannot be used for deck control.”
    Sound like an issue the converter will solve?
    Tom
