Activity Forums Apple Motion No preview-just blank screen
  • No preview-just blank screen
    Posted by Imari on January 11, 2006 at 6:04 am
    I saw that “special case” previously posted this identical problem. The response by pixelmage was this:
    “Silly question, but is your Canvas showing you the alpha channel (instead of color)? Press Shift+C to force the view to the color (RGB combined) mode. Does this alleviate the problem?”
    Special case never reported whether or not this was the problem. I am have the same issue, however, and it is not the channel view setting. I tried all of them. All of the settings display a white screen except for RGB,Red only, green only etc., which make the preview window go black.
    If I do a Ram preview, then I can see the video… huh? I’m totally baffled.
    Just yesterday, I was playing a project with many layers, sound etc.. and it played with no problem. I am playing out to my desktop.
    All I can think is that i recently ran software update and updated apple studio.
    I tried reinstalling the program to no avail.
    I am in motion to the liquor cabinet.
    Thanks for any suggestions,
    Imari
    os x 10.3.9
    G5 Dual 2.5Ghz
    8GB ram
    Motion 1.0
    Doyle Rockwell replied 20 years, 8 months ago 2 Members · 2 Replies
  • Imari
    January 11, 2006 at 6:16 am
    Ok.. I had a nice nip and figured out this silly problem… if this was special cases’ special case, perhaps s/he felt too silly to admit it. I have two monitors. I had recently moved my computer and scrambled up which monitor was my main one (the one attached to my Radeon)… soooo, when I moved the preview window to the other monitor, voila, I’m back in business.. thank you Tanqueray, you make a fine gin and tonic and a whole lot of sense.
  • Doyle Rockwell
    January 11, 2006 at 5:20 pm
    Hey Imari,
    Glad to hear your gin-and-tonic therapy method worked 🙂 It was pixelImage that was having the problem: I had responded, trying to help. Yeah, it looks as though Motion can only draw images in the Canvas on your primary display (the one with the menu bar). I would guess that the RAM preview worked because the images were cached in RAM, first, instead of coming straight from the GPU.
