Activity Forums Boris FX Particle Illusion No png option in particle illusion render, or transparent AVIs
  • No png option in particle illusion render, or transparent AVIs
    Posted by Bob Cat on April 14, 2015 at 5:45 am
    im trying to render in particle illusion (its been years… i havent used the non AE version since like… 2009.
    anyways, i open particle render, reinstalled it several times, because I cannot for the life of me find an ption that deals iwth transparency and pngs? i have the option to render as AVI, and then several codecs within that, but none are the ones mentioned with transparency options in other threads. I also went through the codecs and found none.
    i also can render as wmv, but you know… no. any idea what went wrong?
    Alan Lorence replied 11 years, 4 months ago 2 Members · 1 Reply
  • Alan Lorence
    April 16, 2015 at 3:02 pm
    It’s been a while since I’ve opened the Windows version of pIRender, but if there’s not a place to specify the output format (PNG sequence) then just try adding a “.png” to the filename. There should be a “save alpha” checkbox somewhere that you need to check too. Image sequences are not in the movie (AVI or WMV) options.
    Alan.
    Alan Lorence
    Product Manager
    GenArts, Inc.
    http://www.genarts.com
    http://www.wondertouch.com
