Activity Forums Blackmagic Design No playback at 1080i on Decklink Pro HD
  • No playback at 1080i on Decklink Pro HD
    Posted by Cannon454 on August 21, 2006 at 3:57 pm
    I come to you all again for help. Our current work flow is all SD, However our studio has Decklink Pro HD and a HDLink to preview SD and HD cotent. Today on a whim I decided to copy over the Glacier Bay project and source matieral from the HD Sampler CD and can not obtain realtime playback on my preview monitor it only shows me a still ( at full 1080i res ) of the first frame to be played. Any thoughts. The video playback setting is “Blackmagic Decklink HDTV 1080i 30 HZ – 8 Bit (1920 x 1080) “.
    Cannon
    Setup.
    2.3 Dual Core Mac G5
    Final Cut Studio
    Decklink Pro HD PCI-e
    HDLink
    23” Cinema Display set on 30HZ
    Kristian Lam replied 19 years, 9 months ago 3 Members · 2 Replies
  • The Warped one
    August 23, 2006 at 8:54 pm
    Sounds similar to our problem. I’m watching this thread.
  • Kristian Lam
    August 24, 2006 at 5:39 am
    This sounds more like a configuration issue. Make sure you easy setups match the format of the clips you’re trying to play. If the clips are in DVCPRO HD at 1080i59.94, use “Blackmagic HDTV 1080i 59.94 – DVCPRO HD” in Final Cut Pro’s easy setups (Final Cut Pro > Easy Setup…).
    You can check the format of the clips in Final Cut Pro’s Browser window.
    regards
    Kristian Lam
    Blackmagic Design
