Activity Forums Maxon Cinema 4D No particles in render
  • No particles in render
    Posted by Will Macneil on August 23, 2005 at 8:36 pm
    Hi, I’ve got a pyrocluster setup using particles from a pBorn node passed through a surface position node. Things look good in the editor render, but they’re not there in the picture viewer.
    Any suggestions?
    W
    Brian Jones replied 21 years, 1 month ago 2 Members · 3 Replies
  • Brian Jones
    August 23, 2005 at 11:39 pm
    Environment object with the PyroCluster VolumeTracer on it? Particle Geometry object with the PyroCluster material on it?
  • Will Macneil
    August 24, 2005 at 7:56 am
    Yup, like I said, everything looks good in the editor render, just not in the picture viewer.
    W
  • Brian Jones
    August 25, 2005 at 1:14 am
    With all the pieces in place it’s hard to know what it might be. Can you post an example test?
