Activity › Forums › Apple Final Cut Pro Legacy › No P2 material to Import in Import window
Peter Sassi replied 18 years, 10 months ago 4 Members · 34 Replies
Peter Sassi
November 16, 2007 at 6:51 pmJeremy,
With Tech support, we went back to “creat new user” drag to primary HD, to Secondary HD, Nada!
Some folks are not seeming to have this problem. We took all non Apple things out of the Library/Quicktime, Ran the machine as “Just a Mac” and zippo.
I edited a trailer out of the 43 cards I had stored on the G-Raid with 6.0.1 with no problems. I jumped to the upgrade to get rid of the “lost render” problem. I do have the entire project backed up as a 6.0.1 so all is not lost unless 6.0.1 tries to use QT 7.3. from the newer ver drive.
GOt to test that,
ps
Zachary Johnson
November 16, 2007 at 7:49 pmOkay. I think I might have more info. I looked through my panic logs and saw qmaster referenced in the crashed thread.
After removing all the qmaster and compressor files and installation receipts to all the FCS 6.0.2 apps and reinstalling FCS 6.0, I had no problems importing P2.
(https://docs.info.apple.com/article.html?artnum=302845)
Then I updated FCS apps back to .0.2 omitting the compressor 3.0.2 update. I was able to import P2.
Then I updated compressor (and qmaster) to 3.0.2, and tried importing, and I kernel panic-ed.
The panics don’t happen immediately, so I can’t be certain that {FCS 6.0/QT 7.3} or {FCS 6.0.2(-compressor3.0.2)/QT 7.3} would have kept going panic free. But I can say that I made it through three 16gb cards in each of those configurations. And then when I updated compressor, I kernel panic-ed on the first card I tried.
I’m going back to FCS 6.1 and holding off on a OSX reinstall, as I feel compressor/qmaster may be at fault and not quicktime 7.3.
Or is my logic faulty somewhere?
Jeremy Garchow
November 16, 2007 at 7:55 pm[Zach Johnson] “Or is my logic faulty somewhere?”
NO man, that sounds great.
I would submit this Apple ASAP.
Jeremy
Peter Sassi
November 16, 2007 at 11:57 pmZach,
I tried your method to the tee and still no import of P2…
Darn, thought it would work.
ps
