Activity Forums Apple Final Cut Pro Legacy No output to deck
  • No output to deck
    Posted by Meeroo Sareew on May 9, 2006 at 8:33 pm
    I can’t output from FCP to Betacam deck. It’s driving me crazy.
    First I had a ref. video problem and I solved it with “Y loop trough ref.in”. But now I can’t get video out to deck. Audio is ok, but there’s no video out. Just bluish/purple screen…
    HELP!
    tnx
    m
    Mac Quad 2.5; OS 10.4.6
    Final Cut Studio HD
    Multibridge Extreme
    Sony UVW-1800p
    Sony HVR-M10E
    Walter Biscardi replied 20 years, 4 months ago 2 Members · 3 Replies
  • Walter Biscardi
    May 9, 2006 at 8:56 pm
    [meeroo] “Audio is ok, but there’s no video out. Just bluish/purple screen…”
    What are you feeding out? A bluish/purple screen sounds like you’ve got Component cables connected to your deck, but your system is outputting a Composite Signal.
    Check the outputs on your Multibridge and ensure you’re outputting the correct signal.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Meeroo Sareew
    May 9, 2006 at 9:34 pm
    Hi Walter,
    that’s the same thing that confusing me. In System Preferences/Decklink, under Output I have only: “All Outputs Active”. Other than that I have only “Set DVI output preferences” and “Enable Dual Link 4:4:4 Out” but these are monitoring options.
    Final Cut Studio HD
    Multibridge Extreme
    Sony UVW-1800p
    Sony HVR-M10E
  • Walter Biscardi
    May 10, 2006 at 2:23 am
    [meeroo] “”All Outputs Active”. Other than that I have only “Set DVI output preferences” and “Enable Dual Link 4:4:4 Out” but these are monitoring options.”
    So you don’t have any options to only output Component or only output Composite? Both Component and Composite are hot at all times?
    Then I’m really not sure, you should check with BMD on that one.
