Activity Forums Apple Final Cut Pro Legacy no mpeg support only mts???
  • no mpeg support only mts???
    Posted by Alieninnovation on October 30, 2005 at 9:28 am
    I need to upload some footage to a site.
    But they only want mpeg 2 multiplex.
    So when i choose this format in Compressor. The file turn in to a mts which they won’t except.
    Where is the mpeg 2 format that will stay mpeg/mpg???
    Or does Compressor not support this format?
    iMac G5 17″
    Final Cut Studio
    Jerry Hofmann replied 20 years, 11 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    October 30, 2005 at 2:14 pm
    I wonder if you change the extention of the multiplexed file to .mv or m2v…? Is the problem that the file doesn’t work for them, or that everyone is assuming that it’s the wrong format?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
