Activity › Forums › Apple Final Cut Pro Legacy › No more PVM-14L5!
No more PVM-14L5!
Posted by Winston A. cely on August 29, 2006 at 10:51 pmSo I’ve been looking for a PVM-14L5, and now it looks like they’re all gone! D*mn! I need one with the HD card installed. So what’s the next best thing that’s still CRT and doesn’t coast and arm and a leg?
“If God could do the tricks we can do, He’d be a happy Man.” – Peter O’Toole – “The Stuntman”
Machine Model: Power Mac G5
CPU Type: PowerPC G5 (3.0)
Number Of CPUs: 2
CPU Speed: 2.5 GHz
L2 Cache (per CPU): 512 KB
Memory: 4.5 GB
Final Cut Studio (Not Universal, yet)Winston A. cely replied 20 years ago 6 Members · 8 Replies -
Walter Biscardi
August 29, 2006 at 11:19 pmbeen gone for a while. no clue on what to suggest at this point other than to try a used outlet like the Broadcast Store. http://www.bcs.tv
And there’s no HD card for those monitors. You just get the multiformat version and it’s HD when you feed HD material. The /1 models handle 24p natively.
I’m holding on to mine for a while yet.
Walter Biscardi, Jr.
HD Editorial & Animation for Food Network’s “Good Eats”
HD Editorial for “Assignment Earth”“I reject your reality and substitute my own!” – Adam Savage, Mythbusters
Winston A. cely
August 29, 2006 at 11:30 pmBlast! Thanks for the clarification and suggestion. I did find the 20″ version on ebay, but it was starting at $7800. I’ll try that http://www.bcs.tv next.
Number Of CPUs: 2
CPU Speed: 2.5 GHz
Memory: 4.5 GB
Final Cut Studio (Not Universal, yet) -
Shane Ross
August 29, 2006 at 11:33 pm[walter biscardi] “And there’s no HD card for those monitors.”
To clarify…you don’t need an HD card to feed this monitor an HD signal via component. I bought one with an optional HD SDI card as my capture card was HD SDI only.
I guess I got one of the last of these B&H had to sell. Lucky…
Shane
Littlefrog Post
http://www.lfhd.net -
Winston A. cely
August 29, 2006 at 11:36 pmI found this on http://www.bcs.tv:
SONY / BVMD14H1UIt’s in the price range and looks pretty sweet. Anyone had experience with this? Or does it really matter now? Should we just pull the trigger?
Number Of CPUs: 2
CPU Speed: 2.5 GHz
Memory: 4.5 GB
Steve Eisen
August 30, 2006 at 12:11 amTake at look at Panasonic’s BT-LH1700W or BT-LH2600W.
Steve Eisen
Eisen Video Productions
Director-At-Large
Chicago Final Cut Pro Users Group -
Steve Connor
August 30, 2006 at 12:17 pmThe JVC DTV 17″ CRT monitor is very good and a much better reference monitor than the Panasonic LCD’s in my opinion and it’s cheaper.
Rennie Klymyk
August 30, 2006 at 7:10 pm[Winston A. Cely] “I found this on http://www.bcs.tv:
SONY / BVMD14H1U”These are sony’s better crt monitors. Before I’d pay $7800.00 for the pvm I’d go with the BVM-D but the one you’re looking at is the 1U which has no controll pannel, you need a seperate control pannel ($1000.00) or a monitor that has one. Google BVM-D14H5U which is the same monitor WITH the control pannel on the sides. Fits perfect into a rack this way too. I have one of these and they are excellent. They take the:
BKM 142 ($4000.00) hdsdi input card or the new
BKM 143 ($1600.00) hdsdi input card.
DAC-9213-PVM (Ross) hdsdi input card $1395.00I don’t know what the difference is between these 3 cards other than the price. Ross made an hdsdi card as a replacement for the BKM-142 a few years ago and perhaps that’s why sony has introduced this newer lower priced card. The BKM-142 takes 2 slots up, I don’t know about the other 2 cards.
https://www.rossvideo.com/gearlite/dac9213pvm.html
Only the BVM-D or BVM-E series monitors do HD. The earlier model BVM can not display HD.
The last character in the name U = smpte phouspours or E =ebu phousphors
The 2nd last character (which is a numeral 1 = no control pannel or 5 built in control pannel.
2 different remotes (wired) are available or you can plug into any bvm with built in controls. 1 controller will run about 20 monitors but that’s a pain, I would not want one with out it’s own controller. Way too many menu options.“everything is broken”
Winston A. cely
August 31, 2006 at 4:54 pmWow, thanks for the info! This will help a lot!!!
Number Of CPUs: 2
CPU Speed: 2.5 GHz
Memory: 4.5 GB
