Activity › Forums › VEGAS Pro › No Markers – Vegas Pro 16 to DVD Architect Pro 7
  • No Markers – Vegas Pro 16 to DVD Architect Pro 7
    Posted by Martin Stanesby on January 19, 2019 at 11:57 pm
    Hello,
    I have rendered a file for blu-ray using Sony AVC, and MainConcept Mpeg-2. Both had ‘save project markers in rendered media file’ checked. Once rendered they were not altered or moved.
    Once imported into DVDA 7 there are no markers with them. Also, the ‘Load Markers’ button option is greyed out.
    I can see there is a .sfl file created alongside, and this file is in the same location as the media file. Yet no markers?
    Does anyone know what is wrong, or if I am doing something wrong?
    Thank you for any help.
    Martin
    Francois Pénzes replied 7 years, 8 months ago 3 Members · 5 Replies
  • Mike Kujbida
    January 20, 2019 at 12:22 am
    This was for Pro 13 and DVDA 7 but it might work for you. See the fix from Arthur S. in this thread. Good luck!
    https://www.vegascreativesoftware.info/us/forum/dvda-7-0-not-importing-markers-to-chapters-from-vegas-pro-13–107521/
  • Francois Pénzes
    January 20, 2019 at 12:26 am
    Hi Martin
    Just adding my 2 cents here. Check also here:
    https://forums.creativecow.net/dvdauthoring
    Cheers !
    PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
    Cameras: Canon XF305 + Canon XH-A1
    Blackmagic HyperDeck Studio Mini
    Vegas Pro 14, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
  • Martin Stanesby
    January 20, 2019 at 6:51 pm
    Hi Guys,
    Thanks for your input.
    I found that I was making the mistake of dragging the media into DVDA7 instead of adding media to the menu tree. When I did it via the menu then all the chapters were imported and the add marker button became live too.
    Doh!
    Thanks again
    Martin
  • Mike Kujbida
    January 21, 2019 at 1:15 pm
    Martin, glad to see that you figured it out ????
  • Francois Pénzes
    January 21, 2019 at 8:01 pm
    Hi Martin
    Good on you to give an update. A lot of people come here for solutions and it’s nice to read what worked.
    Cheers !
