Activity Forums Adobe Premiere Pro No Luck Capturing HV30 with Premiere Pro CS6
  • No Luck Capturing HV30 with Premiere Pro CS6
    Posted by Eric Db on April 30, 2014 at 11:45 pm
    Hello,
    I’m trying to capture from my Canon HV30 into PP6 (this is old school, I know). The settings reflect HDV as the capture format, and I’m capturing to an external hard drive. I have device control and can log clips. But, when I select for capture, I wind up with a file that has a .mp3 extension and has no audio or video associated. The batch capture log says the folling: “\Untitled.prproj\Team on the Bench – Capture Failed: Captured no frames”
    I’ve tried both through log & batch capture process and via full tape capture with scene detect on.
    Anyone experience this and know how to get around it?
    Lloyd Plueschow replied 12 years ago 3 Members · 3 Replies
  • Nate Tronick
    May 20, 2014 at 5:27 am
    I just got the exact same problem. If anyone knows a solution, I’d like to hear it.
  • Lloyd Plueschow
    August 26, 2014 at 1:58 pm
    This is from John Wise in 2010 and seems to work for me in the same situation.
    I just wanted to add to this thread a possible fix for anyone working with the following specs:
    Windows 7 (64-bit)
    Canon Vixia HV30
    Adobe Premiere Pro CS4 (5,6)
    I was having the same issues with Adobe not picking up the footage. I spoke with Canon tech support and there were a couple of settings I need to change in both the Camera settings and Adobe Premiere Pro CS4.
    Camera Settings – Make sure in the menu settings of the canon in playback mode you have Autodetect set instead of HDV. Your footage will still be in HD, but Autodetect lets Premiere (and Windows) more easily choose the setting automatically. Also, change the next playback setting 2 to DV Device Locked.
    Premier Pro CS4 Settings – When you initially start a new project, select the HDV folder and then HDV 1080 30fps (unless you filmed in 24, 25 etc then pick those). Now, in the Capture windows, click on Settings and make sure you have 1) NTSC or PAL, 2) Canon, 3) Standard, 4) Non-Drop Frames. Change it from Timecode to just plain Frames in the drop-down box. Then, this is the most important setting, in the Logging tab, click on HDV – settings and change it to DV. This is the key. If you have it on HDV, you can control the camera but nothing will record and you can use the screen or scene detect. You MUST have it set to DV. Again, don’t worry, you will still capture all the HD footage properly.
    This bogged me down for a while, but now I can capture perfectly with Adobe Premier Pro CS4 using Scene Detect. Try it out and you will rest easy going forward. Good luck!
  • Lloyd Plueschow
    August 27, 2014 at 6:15 pm
    Another thing to consider and it is very important. Make sure the camera is the only firewire device during capture. PP does not like more than one firewire device. I have an RME Fireface 400. I have to boot the PC with the sound card disconnected for capture.
    LP
