Activity › Forums › Blackmagic Design › no “live” SDI input
  • no “live” SDI input
    Posted by Robert Lindqvist on December 2, 2005 at 3:58 pm
    Im trying to capture live from a DVCPRO50 camcorder SDI output to a DL Extreme
    SDI input. I can see the SDI as loop-through to SDI monitor from DL SDI output, but not in
    capture inside FCP. I’ve tried various settings but no luck. Going straight to the monitor
    also works just fine.
    What have I missed?
    Dual core 2.3ghz G5
    DL Extreme PCIe
    Latest drivers from BM web.
    All latest updates on FCP, QT and Mac OS.
    4.5Gb ram
    best,
    Robert
    Kristian Lam replied 20 years, 5 months ago 4 Members · 6 Replies
  • Robert Lindqvist
    December 2, 2005 at 4:19 pm
    I’ve done some more testing. Y in works just fine (composit video in).
    Still no SDI input.
    fwiw,
    Robert
  • Trevor Kinsey
    December 4, 2005 at 10:55 pm
    Have you changed the input to SDI in the Blackmagic section of your system settings? Open your MAC system settings and click on the Blackmagic settings icon. Change the input settings to SDI (and the output too if that is what you are using).
    Trevor Kinsey,
    Technical Producer,
    CVP Film and Television,
    Melbourne,
    Australia
  • Robert Lindqvist
    December 5, 2005 at 8:22 pm
    Hi Trevor,
    yes I have checked that.
    Anyone out there with a DVCPRO50 Pana 900 camcorder and SDI output that could try?
    I didn’t get the SDI card from Pana DVCPRO50 VCR, so I can’t try that.
    I’ll try going from my other DL system, G5 to G5….. And I will try to
    connect the camcorder to the other system aswell.
    best,
    Robert
  • Robert Lindqvist
    December 6, 2005 at 9:57 am
    so, I’ve tried from other DL system, it works 🙂 The SDI input is alive.
    Still no picture from Pana camcorder though 🙁
    I’ve got a “SDI cap” SW from Black Magic Design, I will try that and see
    what support can come up with.
    best,
    Robert
  • George Kalishkin
    May 6, 2006 at 1:46 pm
    i got the same problem. composite and component digitize is working, but sdi shows picture only at rewind.
  • Kristian Lam
    May 6, 2006 at 3:22 pm
    [jorje] “i got the same problem. composite and component digitize is working, but sdi shows picture only at rewind.”
    Does your deck support UMID? Try turning it off.
    regards
    Kristian Lam
    Blackmagic Design
