Activity Forums Adobe After Effects Expressions No index for transform parameters in a shape layer’s group?
  • No index for transform parameters in a shape layer’s group?
    Posted by Mio Tanaka on December 26, 2012 at 2:04 am
    I learnt about shape layer index from this page and there’s a thing I cannot fathom out.
    https://www.macprovideo.com/hub/after-effects/after-effects-shape-layer-index-hierarchy
    First, for example, there’s three shape sub-layers in a shape layer’s inner group
    Shape layer
    ▼Contents
    ▼Group
    ▾Path 1
    ▾Fill 1
    ▾Transform
    If you count from ‘Path 1’, there’s three, sort of, parameters in ‘Group’, and I thought the Transform’s index value is three, but actually it says two, the same as ‘Fill 1’.
    So I wondered if there’s no index number for transform parameters in a shape layer’s group?
    In my case, I wanted to control rotation inside the transform option in a group by expression. I used ‘propertyGroup(2)’ rather than ‘propertyGroup(1)’ overall and really didn’t need to use the index of the transform, but it’s good to know.
    Thanks in advance,
    Mio Tanaka replied 13 years, 9 months ago 2 Members · 10 Replies
  • 10 Replies
  • Dan Ebberts
    December 26, 2012 at 2:39 am
    I can’t quite tell what you’re after exactly, but one thing you can do is use a text layer to snoop around the shape layer’s properties. Use the pickwhip to create an expression like this in the text layer’s Source Text property:
    prop = thisComp.layer(“Shape Layer 1”).content(“Shape 1”).transform.rotation;
    Then you can snoop around by adding lines like:
    prop.propertyIndex
    or
    prop.propertyGroup(1).name
    or
    prop.propertyGroup(2).numProperties
    It’s also useful to get Jeff Almasol’s rd_GimmePropPath.jsx script from his redefinery site. It’s a great tool for examing the expression or script syntax to access any property.
    Dan
  • Mio Tanaka
    December 26, 2012 at 4:35 am
    Thank you for the reply. I learnt a few more new things and I’ll check the script!
    Hmmm, I guess my explanation wasn’t good enough. Let me explain it again.
    What I meant was, by using ‘.propertyIndex’, each property’s index is like this:
    ▼Group
    ▾Path 1 —index 1
    ▾Fill 1 —index 2
    ▾Transform —index 2
    Or if there are properties like this…
    ▼Group
    ▾Path 1 —index 1
    ▾Path 1 —index 2
    ▾Fill 1 —index 3
    ▾Transform —index 3
    You can see the Transform’s index is the same as the property above’s, and I wonder if there’s not index number for Transform property at all.
    Thank you,
  • Dan Ebberts
    December 26, 2012 at 6:40 am
    I’m not seeing anything like that. It’s hard to say without seeing the shape layer you have, but sometimes not all the property groups in a shape layer are visible in the UI. Try using the script I mentioned to see if the paths to the properties with the same propertyIndex values are actually different in some way.
    Dan
  • Mio Tanaka
    December 26, 2012 at 7:27 am
    Dan, thank you for the reply again.
    I tried using prop.propertyGroup(2).numProperties, and actually it says the correct value, which includes Transform property I was talking about.
    But then again, when I used this to get an index value, it’s a short value by one…
    value = thisProperty.propertyGroup(1).propertyIndex
    Since it’s quite likely I’m misunderstanding something, here is the screen shot. Maybe you can see why…
  • Dan Ebberts
    December 26, 2012 at 7:52 am
    Fill and Transform are not in the same property group. This is something that is not obvious from looking at the UI. You need the other tools I mentioned.
    Dan
  • Mio Tanaka
    December 26, 2012 at 8:53 am
    I’ve tried the script and got these:
    transform.rotation:
    comp(“tree 2”).layer(4)(“ADBE Root Vectors Group”)(1)(“ADBE Vector Transform Group”)(“ADBE Vector Rotation”)
    fill.color:
    comp(“tree 2”).layer(4)(“ADBE Root Vectors Group”)(1)(“ADBE Vectors Group”)(3)(“ADBE Vector Fill Opacity”)
    It seems there’s no index number for Transform and there’s no way you can access a transform property. But then again, why did the rotation gave me the value 3 in the image I posted…? Are there invisible two values before Transform?
  • Dan Ebberts
    December 26, 2012 at 5:57 pm
    I don’t understand how you’re coming to that conclusion.
    Nosing around a similar shape layer, I get a hierarchy like this:
    Shape Layer
    Contents
    Shape 1
    Blend Mode
    Contents
    Path 2
    Path 1
    Fill 1
    Transform
    Material Options
    Dan
  • Mio Tanaka
    December 27, 2012 at 1:04 am
    My mistake. What I meant was, I thought there’s no way to access Transform by using an index number, since the script gave me these. For Fill there’s (3), an index, whereas there’s no number for Transform. I hope I can get it across.
    transform.rotation:
    fill.color:
  • Dan Ebberts
    December 27, 2012 at 1:30 am
    This works for me (although I don’t know why you would want to do it this way):
    (“ADBE Root Vectors Group”)(1)(3)(“ADBE Vector Rotation”)
    Dan
  • Mio Tanaka
    December 27, 2012 at 6:10 am
    Hmm, interesting. As seeing your comment, probably it’s not as useful as layer index numbers… I’ll study more about expressions. Thank you, Dan!
