Activity › Forums › Apple Final Cut Pro Legacy › No High Quality option on DVCProHD exports ?
Posted by Sam Wells on June 27, 2007 at 8:41 pmExporting DVCProHD using Quicktime conversion seems to default to “Medium Quality” only from FCP 6.0
What has changed, what can I do ?
-Sam
Chris Borjis replied 19 years, 3 months ago 4 Members · 7 Replies -
Shane Ross
June 27, 2007 at 8:45 pmNothings changed. Always that way. But you can ignore the “medium” quality…it outputs a full quality DVCPRO HD image.
But…why are you using CONVERSION? Just export a QUICKTIME MOVIE…not conversion. If you use conversion you’ll get a slight gamma shift in the image…it will brighten a little. This is a bug in QT.
Shane
Littlefrog Post
http://www.lfhd.net -
John Pale
June 27, 2007 at 9:46 pmThe Quality slider is meaningless in that codec (many other codecs, too)…its not a variable compression codec.
Chris Borjis
June 27, 2007 at 10:06 pm[Shane Ross] “If you use conversion you’ll get a slight gamma shift in the image…it will brighten a little. This is a bug in QT.”
with all codecs?
or just dvcpro-hd? -
Shane Ross
June 27, 2007 at 10:09 pm -
Sam Wells
June 27, 2007 at 10:38 pmI’ve noticed that — I use it (Quicktime conversion) when I want to copy over to my Power Book.
Thanks for the reply !
-Sam
Shane Ross
June 27, 2007 at 10:39 pmJust export QT movie…it is exactly the same quality, and no gamma shift.
Shane
Littlefrog Post
Chris Borjis
June 27, 2007 at 11:10 pmThats a real shame because quicktime conversion does a much better job of downconverting HD to SD than compressor does on its highest quality setting.
As good as any hardware downconverter I’ve seen.
