Activity Forums Cinematography No HDMI signal from Small HD 1703 to consumer TV.
  • No HDMI signal from Small HD 1703 to consumer TV.
    Posted by Warwick Field acs on January 22, 2019 at 11:51 am
    Has anyone had any issues sending a HDMI image from the HDMI output of the SmallHD 1703 monitor to an older consumer TV? I have tested the output and got an image on an Atomos Sumo with HDMI soi there is a signal and the cable is OK but when i connect to a regular TV via HDMI I get Signal Unsupported. I tried two different TV’s. The TV’s are 1920×1080. The camera signal from Arri is 3.2k but even when I set it to HD no luck. I don’t really ever use HDMI so don’t know much about it. Has there been a change to the HDMI signal type recently that is incompatible with TV’s over 3 years old?
    Cheers Warwick Field ACS
    Warwick Field acs replied 7 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
