Activity Forums Sony Cameras No HD SDI output signal on my EX-3’s
  • No HD SDI output signal on my EX-3’s
    Posted by Ed Tworek on January 10, 2013 at 11:21 pm
    I have 2 1 year old Sony EX-3’s. Both do not have an HD SDI output signal. I’ve run through every configuration in the menu that I can see. I do have a signal through the Monitor Out port. I reset the camera with no change.
    Yesterday, we attempted recording via a Ninja and several other devices.
    What am I missing?
    thanks
    Ed
    Ed Tworek
    Corporate Video Creations
    http://www.corpvid.com
    Pierson Jacquelin replied 2 years, 6 months ago 4 Members · 4 Replies
  • Michael Palmer
    January 10, 2013 at 11:37 pm
    Select the Highest recording format and make sure the output is campatable with the monitor, I think it’s under Genlock for the output and set to 60i
    Good Luck
    Michael Palmer
  • Bill Griffin
    January 11, 2013 at 12:23 am
    make sure that the fire wire output is turned off, as if it is “on” it will turn off the HD-SDI port. I think that’s the only way the HDSDI will not work.
    Bill Griffin
    HD Cameraman
    972-475-6870
    http://www.dallascamguy.com
    Dallas, Texas USA
  • Bill Griffin
    January 11, 2013 at 12:51 am
    so..go to Menu—-“others”—-go to the bottom, look for “ilink IO” and make sure that its “disabled”..this should fix it.
    Bill Griffin
    HD Cameraman
    972-475-6870
    Dallas, Texas USA
  • Pierson Jacquelin
    March 3, 2024 at 6:22 am
    This works to solve the problem–my output was set to 24pfs. Switching to 60i enabled HD-SDI output.
