Activity Forums Adobe Premiere Pro No fields export settings from Premiere to Media Encoder tips
  • No fields export settings from Premiere to Media Encoder tips
    Posted by Richard Altman on March 22, 2009 at 8:27 pm
    HI,
    I’m fairly experienced with premiere and have been using cs4 for a bit now and would like to know what is the most tried and true method of getting unjagged ie deinterlaced frames. I go like this so far, put my fields to None and i have the container h.264 and 1440 by 1080 for 29.97 frames. Is there more I need to know, the results are ok but i’d like to get some other ideas since this Media Encoder direct export from Premiere is new, maybe there are some things i’m missing.
    thanks
    Mike Velte replied 17 years, 6 months ago 2 Members · 1 Reply
  • Mike Velte
    March 23, 2009 at 10:28 am
    [Dwight Spitz] “maybe there are some things i’m missing.”
    You can get better results by choosing “Use Maximum Render Quality” in the Export Settings fly-out menu (Right edge about half way down).
