Activity Forums Apple Final Cut Pro No Export Destinations
  • No Export Destinations
    Posted by Oli Robert on June 7, 2022 at 1:02 pm
    I’ve had a problem for months where Final Cut shows no export destinations (as pictured).
    The most reliable way to fix this is to trash the preferences, by holding CMD+OPTION.
    The problem usually returns within a day, and I have to set up Final Cut again.
    I’m usually not bad at troubleshooting, but I’m really stuck at where to look with this.
    Any help would be hugely appreciated
    Other steps I’ve taken, without luck
    – Send to Compressor, which doesn’t do anything
    – Adding a destination from the preference window, which causes a crash. Restore Default Destinations also does this.
    – Clean install of FCP
    – Manually deleting the preferences (those in ~/Library/Preferences)
    Oli Robert replied 4 years, 2 months ago 2 Members · 2 Replies
  • Doug Metz
    June 9, 2022 at 9:09 pm
    Destinations have been bulletproof for me from the beginning, and you’re the first I’ve seen mention it. What are you running? (Mac / OS / FCP version)
  • Oli Robert
    June 19, 2022 at 1:24 pm
    It’s strange, for sure. Monterey on M1 iMac with 10.6.3
