Activity Forums VEGAS Pro No dissolves in Ultimate S
  • No dissolves in Ultimate S
    Posted by Harijono Roebana on February 28, 2011 at 8:23 pm
    After some Windows 7/64 updates, Ultimate S Pro 4.1.4 does no longer create dissolves in Quad-CAM, only cuts. (W7, Vegas 10). Strangely, when I open an older veg file, that file allows me to create dissolves in Quad-CAM.
    I tried and checked all the obvious, to no avail. I have been using Vegas and Quad-CAM for years without any problems.
    Is this a known problem? Any suggestions how to solve it?
    John Rofrano replied 15 years, 6 months ago 2 Members · 3 Replies
  • John Rofrano
    February 28, 2011 at 9:55 pm
    [Harijono Roebana] “After some Windows 7/64 updates, Ultimate S Pro 4.1.4 does no longer create dissolves in Quad-CAM, only cuts. (W7, Vegas 10). Strangely, when I open an older veg file, that file allows me to create dissolves in Quad-CAM.”
    It sounds like it’s something unique to one project since older projects seem to work. There are no compatibility problems that I’m aware of. Make sure Automatic Crossfades (Ctrl+Shift+X) didn’t accidentally get disabled.
    Otherwise I would contact VASST at the ultimatesupport email account and we’ll help you work through this.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Harijono Roebana
    March 1, 2011 at 8:17 am
    ‘Auto Crossfades’ was turned on. ‘Unique to one project’ put me back ‘on track’: aligning the files the timeline was set to ‘samples’. That must have created the misalignment for dissolves.
    Riddle solved, thanks
  • John Rofrano
    March 3, 2011 at 3:00 am
    [Harijono Roebana] “…aligning the files the timeline was set to ‘samples’. That must have created the misalignment for dissolves.”
    Yea, if your timeline ruler is in samples, you must specify the crossfade length in samples also. You always have to specify lengths in the duration of the timeline ruler.
    ~jr
