Activity Forums Storage & Archiving No disks were found on which to perform cluster validation tests
  • No disks were found on which to perform cluster validation tests
    Posted by Irrani Dam on November 24, 2009 at 2:07 am
    Hello,
    I have an iSCSI SAN storage (Stonefly HSC) and I have 2 Windows
    2008 servers that have the iSCSI initiator software installed. I have
    given access to both servers so they can both access the array.
    For now, I’ve just had them access it one at a time. (i.e. connect
    server 1 to the array, then disconnect and then connect server 2 to
    it).
    I have the Failover Clustering feature installed on both servers.
    When I run the Validation Wizard it fais and it says that “no disks
    were found on which to perform cluster validation tests”. At this
    point both of the servers were disconnected from the array. I even
    tried to connect one of the servers to the array but it’s telling me
    the same thing.
    I’ve read thru Microsoft documentation but I cannot find any clear
    direction on how to set this up.
    Am I supposed to have the disks dsconnected? Or connected only on 1
    host?
    At what point do I connect both hosts to it?
    Thanks in advance,
    Irrani Dam replied 16 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
