Activity › Forums › VEGAS Pro › “no device selected”
  • “no device selected”
    Posted by Ed Vandenderen on September 11, 2009 at 4:15 pm
    I have attached the hdr-hc9 to pc, have set project for blu ray 1440×1080, 29970fps and unchecked the use external capture app in prefs.
    when I go to capture, the sony capture app shows with “no device attached” It is i-linked into pc.
    What have I missed or forgotten to do here?
    thanks in advance.
    Odd Magne nilsen replied 17 years ago 3 Members · 2 Replies
  • Danny Hays
    September 11, 2009 at 10:47 pm
    Try closing Vegas, connect camera, turn it on, you should hear beep and see new device found, If not, try a different firewire cable. let it finish until it says ready to use, launch Vegas and select HDV, not DV. If you have captured DV and checked always use this setting you need to reset the settings, Search the help file for capturing HDV and it will show you how. Hope this helps.
  • Odd Magne nilsen
    September 12, 2009 at 5:08 am
    Project property doesn’t matter.
    Is your camera set to “HDV OUT”?
    odd magne nilsen
    newbie
