Activity Forums JVC Cameras No component SD out of my JVC GY700??
  • No component SD out of my JVC GY700??
    Posted by Anthony Popolo on January 8, 2010 at 1:18 am
    I am using a few JVC GY700s on a multicamera live event shoot that is running through a NewTek standard defition switcher and want to get the best STANDARD def image from the cameras. Unfortunately the NewTek doesn’t support SDI.
    Does anyone know if it is possible to get a STANDARD Def signal out of the JVC GY700 COMPONENT terminals? They appear to be only HD.
    If I can’t, that means I have to use the COMPOSITE out? Ouch.
    FYI, the the only choices for the NewTek inputs are composite, component(SD) or S-video.
    thanks
    Anthony
    Ryan Mast replied 16 years, 8 months ago 2 Members · 3 Replies
  • Ryan Mast
    January 8, 2010 at 5:43 pm
    According to the manual, no. You can’t get a SD signal out of the component terminals.
    However, you can get SD out of the Y terminal as a component signal. Check page 114 in the manual for settings.
    Meteor Tower Films
    Video creations for music, art, & theater.
    https://meteortower.com/
  • Anthony Popolo
    January 8, 2010 at 7:12 pm
    Just using the Y terminal makes it a composite.
  • Ryan Mast
    January 8, 2010 at 7:15 pm
    Ah yes, sorry — I mistyped. You’re right, it is composite. =)
    Meteor Tower Films
