Activity › Forums › AJA Video Systems › No Component out in 10.5.4
  • No Component out in 10.5.4
    Posted by David Perry on July 26, 2008 at 3:21 pm
    I updated (foolish me) the Apple system to 10.5.4 and now I cannot get component out to work on my AJA 1O/HD
    Anyone else having this issue? HDMI works fine, haven’t tried SDI.
    David Perry
    David Perry
    Carmen Productions
    Gary Adcock replied 18 years, 2 months ago 4 Members · 8 Replies
  • 8 Replies
  • Gary Adcock
    July 26, 2008 at 5:03 pm
    [David Perry] “I updated (foolish me) the Apple system to 10.5.4 and now I cannot get component out to work on my AJA 1O/HD “
    did you update the IoHD driver also?
    you should have if you have not.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • David Perry
    July 26, 2008 at 5:12 pm
    Yes, it was updated before and after 5.1.2
    Now I have those looping problems again also. Were they not fixed? Oh, my bad – I had the system prefs on Aggregate driver. When I took it off Aggregate the audio was fine. But still no component out
    David Perry
    Carmen Productions
  • Jeremy Garchow
    July 26, 2008 at 6:24 pm
    No, don’t have this problem.
    Uninstall and reinstall the drivers? Again?
  • Bob Zelin
    July 26, 2008 at 6:51 pm
    DO NOT USE FCP during your tests. Only use the AJA Control Panel.
    Go to Contro>Test Patterns, and bring up color bars. Do you see anything out of the I/O HD into your monitor ? (you better not be looping thru a VTR for these tests).
    I urge you to do the following for sanity reasons. With color bars up in the control panel, take ONE BNC, and take the COMPOSITE VIDEO OUT and go into the composite video in of your TV monitor. Then, take that same cable, and move it to the OUT Y jack on your I/O HD.
    You should see bars in B+W. If you do, you have your component out working. If you don’t follow Jeremys advice – uninstall and reinstall your I/O HD drivers, and ONLY TEST WITH COLOR BARS from the I/O HD Control Panel – NOT FROM FCP !!!!!!!
    If this still fails, your I/O HD may be dead.
    Bob Zelin (I don’t trust anyones cables).
  • Gary Adcock
    July 26, 2008 at 8:14 pm
    [David Perry] “Now I have those looping problems again also.”
    what looping problems?
    you have not mentioned looping problems.
    gary adcock
    Studio37
  • David Perry
    July 26, 2008 at 8:58 pm
    The Looping is the audio problem. When I play back it plays a few seconds of audio and then keeps repeating it over and over stuck in a short loop.
    I am not getting any component video through the bars in the control panel. I will un-install it again.
    THanks for everyones help.
    David Perry
    Carmen Productions
  • David Perry
    July 26, 2008 at 10:49 pm
    Looks like it has to go back to AJA again. This is the 4th IOHD that they have sent me. One had FW problems, one No component out, one no Red channel component in.
    The composite does not work, no component, HDMI is OK. Maybe it is time to give up on this box and get a Kona 3. I was hoping it would be a software issue but if yours works in 10.5.4 then it must be my unit.
    Thanks for all your help
    David Perry
    Carmen Productions
  • Gary Adcock
    July 27, 2008 at 1:38 pm
    [David Perry] “The Looping is the audio problem. “
    That issue is not your IoHD.
    it is a feed back error in FCP.
    gary adcock
    Studio37
