Activity Forums Apple Final Cut Pro Legacy no communication with deck
  • no communication with deck
    Posted by Cade Muhlig on May 24, 2007 at 9:04 pm
    i asked about this like a week ago, but i still cant seem to get it to work.
    ive got a kona lh and and m10u hdv deck.
    and im trying to capture dvcprohd straight from my deck using the card, and still retain the timcode, and control the deck. i can capture by manually hitting play on my deck, then using capture now, but i cant get my computer to communicate over firewire with my deck. ive been looking all over, and i found the aja whitepaper : aja.com/pdf/support/AJA_whitepaper_HDV.pdf
    but no luck.
    any suggestions?
    cade
    Cade Muhlig replied 19 years, 3 months ago 2 Members · 7 Replies
  • 7 Replies
  • Jeremy Garchow
    May 24, 2007 at 9:35 pm
    You have to set your control to dv in the deck. The component outputs will still output HD. Then set FCP for dv firewire deck control.
  • Cade Muhlig
    May 24, 2007 at 10:58 pm
    yup i did that.
  • Jeremy Garchow
    May 24, 2007 at 11:18 pm
    Can you get deck control without the Kona card involved (i.e. use an FCP HDV preset not a Knna one)?
  • Jeremy Garchow
    May 24, 2007 at 11:23 pm
    Also, any other fw devices connected?
  • Cade Muhlig
    May 25, 2007 at 6:42 am
    yes i can communicate normally,
    and i dont have any other firewire devices connected
    still nada
    anything else??
  • Jeremy Garchow
    May 25, 2007 at 11:11 pm
    You have something setup funky is all I can think of. Your gear is working it seems.
    You need to select a Kona capture preset, open the log and capture window, change the device control in the log and cap window to dv, make sure your deck is set to downconvert dv and it should work.
    DId you speak to AJA?
    Jeremy
  • Cade Muhlig
    May 29, 2007 at 2:52 am
    ill call aja tomorrow.
    thanks
