Activity › Forums › AJA Video Systems › No colour capturing S-Video
  • No colour capturing S-Video
    Posted by Stephan Laeuppi on December 12, 2008 at 2:02 pm
    Hello everbody!
    I finally mangaged to install my new AJA io. I am using it in order to digitize analog PAL video material with Final Cut Pro (5.0.1) on a G5 running on OSX .
    Capturing BetaSP Material via Component (YPbPr) works fine.
    Capturing VHS via Composite Video works fine.
    Capturing S-VHS Video via the SVHS In connection delivers a black and whithe image only. Somehow the Chroma information does not get through. What could be the error?
    Many thanks for your help.
    Stephan
    Todd Reid replied 17 years, 9 months ago 4 Members · 11 Replies
  • 11 Replies
  • Todd Reid
    December 12, 2008 at 3:29 pm
    have you checked all the “prongs” on the svideo cable (male)? Those things are very delicate, and I have bent, then broke a few in my day.
    Try another svideo cable. If everything else is working, I bet its your cable.
    Todd Reid
    Senior Editor
    Digitized Media, Inc.
  • Jeremy Garchow
    December 12, 2008 at 5:11 pm
    [todd reid] “If everything else is working, I bet its your cable.”
    Me too!
  • Stephan Laeuppi
    December 13, 2008 at 1:45 pm
    Thanks for your replies!
    It cannot be the S-Video cable, since going directly to the Sony Video monitor from the S-VHS player with the same cable I get the colour information. The chroma channel gets somehow lost, when I go into the AJA io.
    I tried it using Final Cut and its settings as well as with the Control Panel – no colour on the S-Video.
    Somehow strange that in the control panel I can chose in the Input Menue “S-Video” but only have the choice between Component Output options…
  • Jeremy Garchow
    December 13, 2008 at 7:05 pm
    Is this an io or an ioHD?
  • Stephan Laeuppi
    December 15, 2008 at 8:15 am
    It is an AJA io.
  • Jeremy Garchow
    December 15, 2008 at 6:27 pm
    If you set the AJA control panel is input passthrough, can you get a color image out of the AJA output? (bypass FCP for now).
    Jeremy
  • Stephan Laeuppi
    December 16, 2008 at 2:32 pm
    Hello Jeremy
    Yes I do get a colour image on the AJA-output using composit or component signals. It is only with the S-Video signal that I lose the colour. I checked the S-Video cable (putting it directly to the monitor). The colour is there. As soon as I go into the AJA I only get a black and white image. Do you think the S-Video in socket of the AJA may be damaged?
  • Todd Reid
    December 16, 2008 at 3:46 pm
    have you spoken with AJA?
    You may need a replacement box.
    You are obviously experiencing something that is not the norm.
    Call them and take advantage of your warranty.
    Todd Reid
    Senior Editor
  • Ernie Santella
    December 23, 2008 at 6:16 am
    I also get the B&W issue when I try to digitize from a DVD player through the S-Video in. Try switching to Composite and then back to S-Vid, that usually clears it up for me. Not sure why.
    Ernie Santella
    Santella Productions Inc.
    http://www.santellaproductions.com
  • Stephan Laeuppi
    December 23, 2008 at 8:50 am
    Hello Todd
    Thanks for your message. In the meantime I contacted AJA and told them about the SVideo problem. The response to my email came the very same day.
    Within 4 days I had a replacement box sent from California to Switzerland. I have to say I am really impressed with the Customer Support of AJA! Thumbs up!!!
