Activity Forums Apple Final Cut Pro Legacy No Clip TC Ins/Outs with DV Start/Stop Detection
  • No Clip TC Ins/Outs with DV Start/Stop Detection
    Posted by Lon Mcquillin on January 23, 2009 at 12:22 am
    Doing my first project in HDV, from a Sony HVR-V1U to FCP 5.0.4, using Capture Now with DV Start/Stop Detection. It’s working very well, but when the clips show up in the bins, the In and Out time code column shows “Not Set”. If I click on the In or Out column for a clip, the correct time code appears. If I open a clip, I can move to the head and mark an In, and to the tail and mark an Out, and all is well.
    Is there a way to automatically have each clip in a bin show its starting and ending TC as the default in/out? (Believe me, I’ve scoured the docs and Googled this, without finding an answer to what should be an easy procedure.)
    McQ
    Tom Wolsky replied 17 years, 7 months ago 4 Members · 4 Replies
  • Colin Mcquillan
    January 23, 2009 at 12:46 am
    The next two columns (Media Start and Media End) should show you this info. Unless/until you set an in or out point it will say “not Set.”
    Perhaps not the solution you are looking for, but a quick alternative to having to go the beginning and end of each clip to set your in and out, double click the clip, then hit “x” this will set an in and out at the beginning and end the clip.
    Colin McQuillan
    Van. B.C.
  • Jerry Hofmann
    January 23, 2009 at 1:16 am
    Media Start and Media End show you the TC you’re looking for…
    In and Out columns aren’t like Avid’s… they only show TC when you’ve set and in and out point.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Lon Mcquillin
    January 23, 2009 at 6:13 am
    Thanks very much. As an old Avid editor I’m still getting used to the differences.
    McQ
  • Tom Wolsky
    January 23, 2009 at 8:08 am
    There’s a name from the past. Hi Lon. I just wanted to say hello. I remember using your Cutter software for deck to deck editing way back in the the day.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
