Activity › Forums › Apple Final Cut Pro Legacy › No Capture – Nothing in Bin – Weird QT files in Scratch Folder
Posted by Jun Kitatani on January 9, 2010 at 3:14 amI cannot capture. This has happened once before. I have plenty of disk space and the same dv cam I’ve always used. Am on a Mac Pro intel Leopard w/ FCP 6.06. FCP controls the cam but the capture window only flashes and nothing gets into the bin. Some weird QT files show up in my scratch folder.
Don Greening replied 16 years, 8 months ago 4 Members · 7 Replies -
Rafael Amador
January 9, 2010 at 4:58 am[Jun Kitatani] “Some weird QT files show up in my scratch folder.”
Some AV QT files or so?
What kind of HD are you using for capturing?
Rafael -
Jun Kitatani
January 9, 2010 at 5:22 amI checked my scratch disc on the external drive to check if it was getting anything and I have several untitled QT files which I cannot open. Each of those are stamped with the exact time I had attempted to capture. Probably dreaded software problem.
Don Greening
January 9, 2010 at 5:27 am[Rafael Amador] “What kind of HD are you using for capturing?”
Indeed. And make sure the hard drive you’re capturing to is formatted in Mac OS Extended.
– Don
Jun Kitatani
January 9, 2010 at 6:02 amIt’s an Iomega 500 GB (HDD 1H4). Firewire & ESATA. Drive was formatted a long time ago and hasn’t changed since I began using it nearly a year and a half ago. I was able to capture to it just last month.
Rafael Amador
January 9, 2010 at 6:49 amYes, and not a USB HD.
Don have a happy 2.010.
Hope the winter is treating you well.
Cheers,
rafael -
Walter Biscardi
January 9, 2010 at 1:23 pm[Jun Kitatani] “. Drive was formatted a long time ago and hasn’t changed since I began using it nearly a year and a half ago. I was able to capture to it just last month.”
All media drives should be cleaned regularly. That means erasing and re-initializing them. A drive that has not been cleaned for a year and a half is probably badly fragmented.
We try to clean our drives off at least every three months to keep them clean. I have some extra drives around so we can dump the media off the array, erase the array, and then copy the media back.
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author.
HD Post and Production
Biscardi Creative Media“Foul Water, Fiery Serpent” now in Post.
Creative Cow Forum Host:
Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital. -
Don Greening
January 11, 2010 at 3:42 amThanks, Raf. Here’s hoping you have a great 2010 as well.
– Don
