Activity › Forums › Adobe After Effects › No Brainstorm in AE CS3
  • No Brainstorm in AE CS3
    Posted by Mike Mackenzie on November 26, 2009 at 1:23 am
    Hello…
    I’m trying to access Brainstorm in CS3 but I’m having a small problem. I select effects in the effects control panel, hit the Brainstorm icon above the timeline, but I am not getting the Brainstorm popup. Something is happening, as AE is expecting keyboard input (I’m getting that noise when you press keys outside of a dialogue box) so I believe BS is activting, I’m just not seeing the nine-frame panel. I’ve tried various layouts including Default with no luck. Any suggestions are greatly appreciated!
    PS I just noticed, in the Info panel it says “Adding Folder
    —Brainstorm Temp Folder—”
    I waited to see if this was just a long process, like your first ram preview, but this doesn’t seem to be the case. I’ve also tried deleting my prefs, still no luck.
    Motion Graphics Designer / Art Director
    Boston, MA
    System:
    Mac/Leopard
    2 x 2.8 GHz Quad-Core Intel Xeon
    6 GB 800 MHz DDR2 FB-DIMM
    Mike Mackenzie replied 16 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
