Activity Forums VEGAS Pro No audio with my avi video
  • No audio with my avi video
    Posted by Hobonicus on July 20, 2006 at 9:33 pm
    I’m trying to import a large avi file into vegas. Whenever I do, it builds the peaks for god knows how long then an error window appears saying:
    An error occured during the current operation
    An error occured while opening a codec.
    The video works just fine, I can edit it however I want. But the audio says “Peaks not avaliable” and there is no sound. If I play this in any player the audio works just fine. If I try to render will there still be no sound? What can I do to have the audio show up?
    Thank you.
    Edward Troxel replied 20 years, 1 month ago 3 Members · 2 Replies
  • Ronnie Smith
    July 22, 2006 at 8:27 pm
    The only thing I could recoment is to make sure you have the latest update for you Vegas Video edition by going here and downloading it.
    Hope this helps,
    Ronnie Rokk
  • Edward Troxel
    July 23, 2006 at 11:16 am
    You need to figure out what format the audio is in and make sure you have a codec available for that type. (AVI is just a wrapper that can hold many different types.) You can always try using some other program to convert the audio to a standard WAV file.
    Edward Troxel
    JETDV Scripts
