No audio will play until I export as an .mpeg
I’ll capture a clip from a Mini DV, I’ll put it into the timeline and the clip will play perfectly except for the fact that there is no sound.
I’ve checked the waveform and the audio is there, it just doesn’t play back. Furthermore, when I export as an .mpeg and play the whole thing in Quicktime, the sound is perfectly fine.
What’s going on? If it’s at all relevant, I’m shooting in 24pa (and capturing with NTSC DV Advanced)and using Final Cut 6.
