Activity Forums Adobe Premiere Pro No audio when playing project
  • No audio when playing project
    Posted by Dreamweaver13888 on January 9, 2007 at 11:50 pm
    When I play my project, Premiere doesn’t play the audio. I need it to play the audio in order to know when to cut it, so this is a problem. When I drag the marker I can hear the audio playing at several times speed, but not otherwise. Toggle Track Output is on, so i haven’t accidentally muted my video, and the speakers are working. Is there some way to fix this, or is it merely a bug?
    Harm Millaard replied 19 years, 8 months ago 4 Members · 3 Replies
  • Marisu Fronc
    January 10, 2007 at 12:26 am
    Is your audio set to play thru the desktop or thru an external device? Check the setting in preferences and make sure it’s correct.
    marisu
  • Aanarav Sareen
    January 10, 2007 at 2:30 am
    Do you have a DV device connected to your system? If so, unplug that.
    – Aanarav
  • Harm Millaard
    January 10, 2007 at 4:23 pm
    This is a common occurrence with non MSDV codecs, like DivX and the like. What is the codec used?
