Activity › Forums › Adobe After Effects › No Audio Whatsoever In My Final Render
  • No Audio Whatsoever In My Final Render
    Posted by Mindy Weisberger on April 10, 2010 at 4:58 am
    I’ve been banging my head against the table over this for the better part of a day.
    I’m working in CS4 on a MacBook Pro, OSX.5.8. I have a lovely handful of AIFF files. They play in Quicktime. They play in Final Cut. They play in After Effects in RAM preview. But they don’t render out of AE in my final Quicktime. Audio output’s enabled in the output module, and they’re not muted in the sequence. They’re all identical (settings-wise) at 16bit/stereo/48.000 Khz.
    I’ve tried just rendering the audio. I’ve tried pre-rendering. I’ve tried everything except sacrifice to Ba’al.
    Anyone have any thoughts on what might be behind this? Because at this point I haven’t a clue.
    Much thanks!
    Mindy Weisberger
    Media Producer
    Steve Roberts replied 16 years, 5 months ago 2 Members · 5 Replies
  • Mindy Weisberger
    April 10, 2010 at 2:49 pm
    Nope, it’s enabled, has a custom template and everything.
    It looks like the problem was with the audio files – even though they’re playing in RAM preview, I expanded them in the comp and saw that there were no waveforms. I have no idea what THAT was about, but I converted the files and now they’re fine. Go figure.
    Thanks for answering!
    Mindy Weisberger
    Media Producer
  • Steve Roberts
    April 10, 2010 at 2:50 pm
    Got a screencap of your a) timeline b) Output Module?
  • Steve Roberts
    April 10, 2010 at 3:31 pm
    That’s weird.
    What did you change to make them work, for our loyal readers?
  • Mindy Weisberger
    April 10, 2010 at 6:54 pm
    I wish I knew. I send the audio into Amadeus and did a straight export as AIFFs (though at 41KHZ rather than 48), and that seemed to do the trick. Though I have no idea why – there’s no reason why After Effects should have trouble with 48. And like I said, the original clips played just fine in RAM preview. So…weird. But solved, at least.
    Mindy Weisberger
    Media Producer
  • Steve Roberts
    April 11, 2010 at 12:17 pm
    Hm. Thanks.
