No audio vegas pro 14
Posted by Josh Freeman on July 13, 2018 at 4:58 pmWhen I import audio in Vegas 14 it doesn’t work, no matter what format I chose (I’ve tried .mp3 .wav .flac) it doesn’t work.
I tried searching the internet but only found what to do if imported video doesn’t have audio. When I import video the audio is fine but when I try importing audio it shows the audio track on timeline but it’s silent, audio is not muted and I tried relaunching vegas and restarting PC
If this helps, the audio visualizer is also not working…George Dean replied 8 years, 2 months ago 4 Members · 12 Replies -
Francois Pénzes
July 14, 2018 at 11:32 amHi Josh
Can you give us a step by step description of what you do when trying to import audio. (click & drag, import, open,….)
Can you give us a screen shot of you time line after trying to import audio ?
A MediaInfo on your file would also help. https://sourceforge.net/projects/mediainfo/
Cheers !
PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
Cameras: Canon XF305 + Canon XH-A1
Blackmagic HyperDeck Studio Mini
Vegas Pro 14, User since Vegas 3.0\’\’When the cutting stops, the editing begins…\’\’
Josh Freeman
July 14, 2018 at 1:31 pm -
Graham Bernard
July 14, 2018 at 6:16 pmHmm… I don’t like the look of that MP42 AUDIO LAME. Nasty. I’m thinking it’s SOLOED off your Audio Tracks.
* Grazie
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
Francois Pénzes
July 15, 2018 at 12:08 amHi Josh
Can you play your audio with something else? Something like Audacity
Your file is in a Mpeg container. Lossy format to boot. For more user friendly info on audio formats, follow this link:
https://www.lifewire.com/what-makes-an-audio-format-lossy-2438561
While in Audacity, you may want to convert it into another format and see if it will work better for you.
Let us know what happens
Cheers !
Josh Freeman
July 15, 2018 at 10:42 amI made this file in audacity and exported as .mp3.
When it didn’t work I exported it in .wav
Still didn’t work
Same with .flacWhen I import VIDEO in vegas the sound works so either I have problem with importing AUDIO in vegas or problems with exporting audio from audacity.
Can you sugest a format to export? -
George Dean
July 15, 2018 at 1:49 pmJosh, have you recently reset Vegas and deleted the application cache? If not, it may help.
Best Regards……George
Francois Pénzes
July 15, 2018 at 8:53 pmHi Josh
Follow George’s advice. Here’s the procedure, and then some…
https://www.moviestudiozen.com/doctor-zen-faq/573-how-to-reset-sony-software-to-default-settings
Cheers !
Josh Freeman
July 16, 2018 at 7:53 pmIt fixed audio issues but now every time I try to render something with any preset (tried 3 allready) it renders quickly and outputs blank video ~4 mins long shoving only black screen and no audio……………
What do I do, I can’t render anything!!! -
Josh Freeman
July 16, 2018 at 8:37 pmOk I solved it, just took backup render deleted project and started over, it’s now rendering, I will update you after 6h when it finishes.
