Activity Forums Adobe Premiere Pro No audio playback in source window
  • No audio playback in source window
    Posted by Jim Wilcox on June 26, 2009 at 6:16 pm
    Just trying to work with some P2 media and I cannot seem to monitor audio in the source window. Same clips in the timeline play back audio just fine. I can see waveform in source window too, just can’t monitor. Playback settings in source window are the same (desktop audio). Is this something simple that I am missing? Not a regular Premiere user…
    Marten Kopp replied 17 years, 2 months ago 2 Members · 3 Replies
  • Marten Kopp
    July 2, 2009 at 9:10 am
    Did you allready found the sollution? I am having kind of the same problems. And it makes it really hard to edit without previewing the sound. I allready figured out I had to do some sound channel mapping. So my files have audio in the bin preview. And in the source monitor they show a waveform but it still refuses to play the sound.
  • Jim Wilcox
    July 6, 2009 at 3:48 pm
    Marten,
    I have found no solution to date. Still hoping someone out there has something for us. I can play back clips directly in the bin with audio, but as soon as they drop into the source window its MOS. Same on two separate systems.
  • Marten Kopp
    July 6, 2009 at 3:55 pm
    Hi Jim,
    Thanks for your reply. To bad you didn’t figured it out allready. It’s actually quite anoying. I get them to play the audio in source monitor but only when I set the audio track from 1 to 2. Really wierd. But I got over 190 clips so it will be a lot of work to switch them all.
