Activity Forums AJA Video Systems No audio out of Kona LH other than SDI
  • No audio out of Kona LH other than SDI
    Posted by Bill Hall on April 17, 2009 at 12:52 pm
    I am trying use our Kona card to down convert HD video to SD and master to one all of our SD decks. So far I’ve managed to get the video out and routed without a problem but I can’t seem to get the hang of the audio.
    The only audio I get is via SDI embedded. This would be fine except I have it hook up to a JVC Digital S machine, BR-D92U, that has problems handling SDI embedded audio. The machine can accept AES digital audio and analog XLR inputs. I tried to connect the AES audio and the Analog out but I get nothing.
    The Kona LH manual didn’t seem to have much to say on the subject of audio output settings and my guess is that it should be automatic. I could use any help you can give.
    My set up is a Power PC MAC G5 Dual 2GHz with 3.5 GB of ram. Running OSX 10.6 and Final Cut Pro 6.0.5. The Kona card I am using is the Kona LH.
    Doug Beal replied 17 years, 4 months ago 3 Members · 4 Replies
  • Bob Zelin
    April 17, 2009 at 4:18 pm
    play back bars and tone. Plug your Kona LH directly into a mixer or speaker – not your VTR.
    Do you get any audio. DO NOT USE YOUR VTR for these tests.
    Bob Zelin
  • Bill Hall
    April 17, 2009 at 5:09 pm
    I’m out of the office now and won’t be able to get back to this problem till Wednesday but I’ll let you know how it goes with the mixer.
  • Bill Hall
    April 23, 2009 at 8:22 pm
    Thanks a lot turns out it was the deck. Sometimes you can’t forest for the trees and miss the easy solution. This should make the HD switchover go a whole lot smoother. I love this little AJA Kona card.
  • Doug Beal
    April 23, 2009 at 9:29 pm
    all outputs are active.
    Doug Beal
    Editor / Engineer
    Rock Creative Images
    Nashville TN
