Activity Forums Apple Final Cut Pro Legacy no audio on mpeg movie when imported into FCP
  • no audio on mpeg movie when imported into FCP
    Posted by Dan Martland on August 2, 2006 at 3:12 am
    Dont know if anyone else has come across this problem, But the nature of my work is to sometimes use mpeg videos downloaded of the internet. It all plays fine in quicktime player but as soon as i import in to final cut there seems to be no audio. NIGHTMARE!!
    The only way i have got round this, is to record another audio track from the quicktime movie (on the desktop) and then try to sync the image and audio back up. This is very long winded and must be another way!
    I owe anyone a large beer if they can help.
    Many thanks.
    dan@dantv.co.uk
    http://www.dan@dantv.co.uk
    FCP studio 5.1.1
    Graeme Hague replied 20 years, 1 month ago 5 Members · 5 Replies
  • Bret Williams
    August 2, 2006 at 3:37 am
    Final Cut doesn’t truly support mpeg. Just quicktime (.mov not .mpeg) files. Simply export from QT Pro or compressor as a quicktime that matches your sequence setttings.
    I prefer Terrapin Rye Pale Ale.
  • Jeremy Garchow
    August 2, 2006 at 3:42 am
    You can also download a free program called MPEG Streamclip that will convert your MPEG 1 or 2 movies to a quicktime compatible format.
    https://www.google.com/search?client=safari&rls=en&q=mpeg+streamclip&ie=UTF-8&oe=UTF-8
    Jeremy
  • 13 Create COW Profile Image
    13
    August 2, 2006 at 5:24 am
    Some mpegs have this problem (I believe it hase to do with the tpe of mpg and how they compressed it), if you try to export it from Quicktime Pro you will probably have the same problem. I would try and use MPEG Streamclip.
  • Dan Martland
    August 2, 2006 at 5:38 am
    I think i owe alot of beers to you all. Thank you all so much, you really are a bunch of life savers!
    Many thanks! The milky bars are on me!!
  • Graeme Hague
    August 2, 2006 at 8:27 am
    I had the same problem and solved it by converting them to AVI files. It surprised me, too!
    Cheers, Graeme.
