Activity › Forums › Apple Final Cut Pro Legacy › no audio on log & capture
  • no audio on log & capture
    Posted by Kelly Marcott on May 11, 2006 at 9:14 pm
    not sure what’s happening…not hearing audio while capturing. I see levels on deck and in FCP, speakers are on & not muted. Am i missing something? Using mini-dv panasonic deck with G5 using firewire…
    kelly
    Kevin Monahan replied 20 years, 4 months ago 3 Members · 4 Replies
  • Brian Pitt
    May 11, 2006 at 9:22 pm
    In the Log and Capture window, go to the Clip Settings tab and check the Preview box under the Audio section.
  • Kelly Marcott
    May 11, 2006 at 9:43 pm
    i forgot to mention that in my first post that it is selected….thats probably what’s perplexing me…is their another culprit?
  • Brian Pitt
    May 12, 2006 at 4:01 pm
    make sure that default is selected under View>Audio playback
  • Kevin Monahan
    May 12, 2006 at 7:20 pm
    Kelly,
    If you set up your FCP system w/o looking at the manual, you probably don’t have your speakers connected properly.
    Connect your speakers to the deck/camcorder and not the Mac. Connect the NTSC monitor to the deck/camcorder as well. Make sure that the View Menu is set to External Video>All Frames.
    The only problem with the “spec” setup is that audio from your Mac may also need to be routed to the same speakers, right?
    In that case, I have a small mixer set up to my speakers. I feed the deck/camcorder’s cables and a cable from the mac to the mixer so I can have both a spec audio setup for FCP and can run iTunes, Soundtrack the same way.
    If you can’t afford a mixer, a small Y-adapter cable from radio shack will do the trick.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
