no audio on DVD produced with Sony DVD archetect
Posted by John Todd on January 22, 2009 at 9:32 pmI am producing a movie in 5.1 surround. When I send it to Sony DVD Archetect to produce a DVD, there is no sound at all on the DVD.
I am rendering video and audio seperately. What am I doing wrong?John Todd replied 17 years, 7 months ago 3 Members · 8 Replies -
Terry Esslinger
January 22, 2009 at 9:59 pmWhen you preview the DVD in DVDA before burning is there sound? If not is there a sound file noted in the media listing when you highlight the video to be played. Its possible you did not import sound with the video.
If you rendered as suggested that is use MainCncept DVDA compatible MPEG2 stream for the video and AC3 for the audio and render separately, you need to be sure that the two files have the same name and are in the same folder. If you do that, when you bring the video over, the sound file will automatically come with it. -
Mike Kujbida
January 23, 2009 at 2:07 amIn addition to Terry’s suggestions, did you set DVD Architect’s project properties to AC-3 5.1 surround?
John Todd
January 23, 2009 at 12:15 pmI have sound in preview, but when I burn the DVD there is no sound.
I am giving the two files the same name, and they import together. You can see the sound track in the time line. But it doesn’t burn. -
Mike Kujbida
January 23, 2009 at 3:00 pmHow are you checking/listening to the DVD?
If it’s on a DVD hooked to a TV, do commercial DVDs in 5.1 play back properly? -
Terry Esslinger
January 23, 2009 at 4:34 pmWill a standard DVD (movie from blockbuster) play with sound in the computer?
