Activity › Forums › Avid Media Composer › no audio on Avid DV ingest – yet works w/ iMovie
  • no audio on Avid DV ingest – yet works w/ iMovie
    Posted by Paul Dougherty on November 17, 2008 at 1:31 pm
    I want to capture/ingest from a dvd player (Pioneer DVR-310) that has a firewire-out port, on my G5 (2004) with the Mojo & all other firewire devices disconnected. Video is fine but no audible sound, audio trks 1 & 2 are active for capture, 1394 is the input hardware, the Avid (MC 2.7.2) recognizes that it’s seeing 48k coming in because when I switch the Audio Project setting to 44k it says after capture “expecting 44k & getting 48k – switch your Audio Proj. setting.” In Stats view the lists a DV captured clip as having 48k but there is no sound on playback or movement on the VU meter. As my subject line says iMovie will ingest in the same configuration just fine, any ideas on how to get this working for Avid capture?
    Thanks in advance for any ideas.
    Paul Dougherty
    Paul Dougherty replied 17 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
