Activity Forums Adobe Premiere Pro No Audio Meter Scale
  • No Audio Meter Scale
    Posted by Jeff Coleman on May 10, 2016 at 2:27 pm
    I don’t have dB scale in my Audio Meter pane (i.e., no graticule/numbers on right side of window). BTW, the scale IS present in PPro 2014.2/8.2.0 (65)
    Is there a way to turn that on/off, or is it a bug?
    Premiere Pro 2015.2 [9.2.0 (41)]
    Mac Pro Late 2013, 8-core, AMD FirePro D700
    OS 10.9.5
    audio meter
    VU
    scale
    graticule
    Premiere Pro CC 2015
    Mac OS
    Jeff Coleman replied 10 years, 4 months ago 2 Members · 3 Replies
  • Ann Bens
    May 10, 2016 at 11:00 pm
    Make the audio meter wider.
    Adobe Certified Expert Premiere Pro CS6/CC
    Adobe Community Professional
  • Jeff Coleman
    May 11, 2016 at 12:51 pm
    Thanks, but it seems to me that I shouldn’t have to make the audio meter any bigger in PPro 2015 than I had it in PPro 2014 in order to see the scale.
    However, if I make the audio meter REALLY wide, it turns the meter on its side (so that the level indicator is rising from left-to-right) and displays a scale at the bottom of the pane. This is not desirable.
    Another suggestion?
  • Jeff Coleman
    May 11, 2016 at 2:40 pm
    Figured it out. So simple….
    The entire layout was a bit too big on the monitor. I slid over the whole lefthand PPro display layout and I could see the scale on the right hand side of the meter now. I shrunk the window a tad and filled the screen.
    All is well now.
    Thanks.
