Activity › Forums › DaVinci Resolve › No audio in selected video clips
  • No audio in selected video clips
    Posted by Marlies Klamt on March 14, 2018 at 12:47 am
    I have just imported a lot of video clips all of what contain sound. 90 % of the clips are alright, but with some there is no sound even though I can see the waveform and in other programs they work alright. Reimporting these clips does not do the trick. They are recorded the same way as the other clips which all work. I am using version 12.5.4.019
    Any idea what could cause that and how I can solve the problem?
    Michael Gissing replied 8 years, 6 months ago 2 Members · 3 Replies
  • Michael Gissing
    March 14, 2018 at 2:09 am
    Check the sample rate, track number and bit depth are the same.
    Resolve 14 is such an improvement in many areas including sound that it might be worth considering updating, with the usual cautions if you are mid project and backups of projects and database is done.
  • Marlies Klamt
    March 15, 2018 at 3:46 pm
    Thank you for your quick reply, Michael! It turns out, that the next day the clips (most of them) worked. I assume that it has to do with lack of memory on my PC. That would also explain why its mostly long clips that do not have sound.
  • Michael Gissing
    March 16, 2018 at 12:35 am
    32 gig RAM and a good GPU makes life better.
