Activity Forums Adobe Premiere Pro No audio in Premiere Pro CS3
  • No audio in Premiere Pro CS3
    Posted by Christopher Long on August 17, 2008 at 9:40 pm
    Hi
    I recently imported video and audio from a Panasonic AG-HVX200 into Premiere Pro CS3.2. I am not getting any audio but I do see in the Audio Master Meters, audio levels. All other applications have sound, just not Premiere Pro.
    Any advice would sure be appreciated!
    My Software:
    Adobe Creative Suite 3 Master Collection
    My Hardware:
    HP Pavilion Elite m9260f Desktop PC
    Windows Vista Home Premium 64-bit
    2.66GHz Intel Core 2 Quad Q6700
    1TB hard drive
    4GB of DDR2 memory
    Blu-ray/HD DVD SuperMulti drive
    NVIDIA GeForce 8600 GT graphics
    Two 22″ Widescreen HD LCD Displays
    Logitech Z-5500 5.1 THX-certified Dolby Digital/DTS Digital Speaker System
    Brie Hope replied 14 years, 8 months ago 14 Members · 18 Replies
  • 18 Replies
  • Terry Kampowski
    August 18, 2008 at 11:23 am
    Try to play it in Bridge and see if you have audio there.
    If so, it probably has to do with your audio drivers setup.
    I’m not sure if that is in Preferences or you may have to go back to your Control Panel and fiddle with the settings. I’m assuming you have more than one audio driver.
  • Christopher Long
    August 18, 2008 at 11:43 pm
    It does play in Bridge.
    I even put in a .wav file and still no audio in Premiere Pro.
    I think I have only one audio driver.
  • Terry Kampowski
    August 19, 2008 at 12:04 pm
    Does the audio play in the project panel?
    Do other files play fine, just not this one?
    Put another video right above the problem video and see if you can hear sound.
    Also move the video/audio to another timeline, just to make sure the volume is not turned down.
  • Christopher Long
    August 20, 2008 at 1:17 am
    I got it to work. Thanks.
  • Alex Schiller
    August 21, 2008 at 8:13 pm
    How did you fix the problem? I´m having the same problem. Does it have to do with the driver?
    Cheers
  • Willem Burger
    September 1, 2008 at 2:50 pm
    Im having the same problem. Any help on this?
    -I have CS2 and CS3 trial. New machine with Vista Home 32 bit.
    -also dual Core 3.1 ghz, Coolmaster box.
    -Tried all formats (mp3, avi, mpeg, nothing with sound).
    -sound in bridge, outside premiere and even if renedered and saved out from Premiere.
    -Sound bar goes up and down , when previewing. But no adio on speakers
    -does not play in preview (top left).
    -Tried on all audio tracs
    Ony one audio device. Played with all options on Project settings and preference settings.
    Thanks in advance
  • Eddie Lotter
    September 1, 2008 at 3:59 pm
  • Josh Flentner
    September 17, 2008 at 12:12 am
    Hey. I had the same problem. Just figured out how to fix it and so I figured I’d share the knowledge.
    Edit –> Preferences –> Audio Hardware –> ASIO Settings. From there just make sure all the devices are checked.
    Hope this helps someone!
  • Adam Kaplan
    September 26, 2008 at 4:39 pm
    I am having a similiar problem. I check my preferences and it looks fine. All the clips i captured in hdv last week work perfect but the clips that i captured from vhs last month were working fine until yesterday. I now only get audio levels but no sound. My HDV clips are still working properly. Any Other Ideas??
  • Eddie Lotter
    September 26, 2008 at 8:26 pm
