Activity Forums Adobe After Effects No Audio In AE 6.5
  • No Audio In AE 6.5
    Posted by Jasonphippsfx on June 8, 2006 at 12:59 am
    In the middle of a project, After Effects suddenly quit handling audio! Everytime I try to preview or render a comp with audio, I get this error message…
    After Effects error: opening file “%s”.sound channel – can’t open Quicktime handler (-2004).
    I’m using Ae on Mac OSX, and this problem started right after I started using Audacity. I tried trashing the preferences, re-installing AE, and updating to the newest version of Quicktime, but nothing has worked so far. Can anyone help me?
    Jasonphippsfx replied 20 years, 3 months ago 2 Members · 2 Replies
  • Tim Kurkoski
    June 8, 2006 at 3:26 am
    If I remember correctly, you have to change the system audio settings back to 48khz (or less than 68khz, if my memory is to be trusted). Go to Applications/Utilities and open the MIDI Setup app. I think. I’m at home and not near a Mac right now. In any case, the options are in the lower-right corner. Audacity probably tweaked them up to the max.
  • Jasonphippsfx
    June 12, 2006 at 3:29 pm
    Thanks Timothy, That fixed the problem right away!
