Activity Forums Apple Final Cut Pro Legacy No Audio Capture FCPHD – not the regular problem
  • No Audio Capture FCPHD – not the regular problem
    Posted by Amy Hildenbrand on November 30, 2006 at 2:21 pm
    I’ve gone through the archives and looked extensively for a solution to my problem and, having found none, I come now to everyone for guidance. I’m running FCP HD/4.5 on a Dual 2.5G machine, tons of RAM, OS 10.4.8. I’m capturing NTSC analog video through the Canopus ADVC-100 and the problem is I’m not getting audio. The monitors play the audio I know is there, but it’s not getting captured. I have multiple decks connected and have tried capturing through the Beta deck with the same results, so it’s definitely software-related.
    I’ve tried trashing prefs & FCP user data, and View/External Video is set to Off.
    Thanks for any help,
    Amy Hildenbrand
    ahildenbrand@newyorkfestivals.com
    Joe Paolo replied 19 years, 10 months ago 3 Members · 7 Replies
  • 7 Replies
  • Bill Kelly
    November 30, 2006 at 3:11 pm
    Make sure when you have Log & Capture open, in Clip Settings, that you have the Audio box checked. I know that’s pretty basic, but sometimes the simple things are what trip you up. I’ve made that mistake before and given myself the classic forehead slap and “Doh!”.
  • Amy Hildenbrand
    November 30, 2006 at 3:31 pm
    I don’t specifically see an audio box to check, but under Clip Settings I am attempting to capture Aud+Vid. And I’ve certainly slapped my forehead before, so thanks for having me check the obvious!
    –amy
  • Joe Paolo
    November 30, 2006 at 7:41 pm
    While you’re checking the obvious, I think the analog inputs are on the back of the unit. The outputs are on the front. (or is it the other way?) Double check your connections. I also sometimes have to restart my whole system to recognize the box.
    joe
  • Amy Hildenbrand
    November 30, 2006 at 7:52 pm
    I checked the connections and everything’s fine. I also have the monitor running out from a splitter at the same level as the input and I can hear audio that way but no dice through FCP. I just now did a hard restart after trashing the prefs yet again with no luck. I wish I knew what was happening!
    -amy
  • Joe Paolo
    November 30, 2006 at 9:30 pm
    Have you actually captured something and checked the file? The audio meters do not register during capture even though you are capturing audio.
    joe
  • Amy Hildenbrand
    November 30, 2006 at 10:16 pm
    Yes, I’ve checked the captured file, and it is completely without audio.
    -amy
  • Joe Paolo
    November 30, 2006 at 11:27 pm
    I’m out of ideas. Try a different firewire cable? Do you have a DV camera that you could test your fire connection with? It might be a problem with the ADC unit.
    joe
