Activity Forums Adobe After Effects no audio after rendering
  • no audio after rendering
    Posted by Vincent Munoz on August 6, 2007 at 1:46 am
    beginner here.
    i can preview my audio using ctrl drag the timeline or the audio preview using COMPOSITION>PREVIEW>AUDIO PREVIEW (Work Area).
    but when pre-rendering, my audio is missing. can someone please help me. thanks!
    Greg Akeson replied 18 years, 2 months ago 3 Members · 4 Replies
  • Michael Duff
    August 6, 2007 at 1:55 am
    so there is no audio when you do a RAM preview? Are you hitting 0 on the keypad to preview?
    check in Composition -> Preview -> Audio … it should be ticked…
  • Vincent Munoz
    August 6, 2007 at 4:00 am
    yes, there’s a preview in ram preview, audio preview(here forward) and audio preview(work area).
    if i hold down control(ctrl) while dragging on the timeline, there is also.
    when rendering, there’s none.
    in render settings > output module > output audio: OFF
    how can i turn it on?
  • Vincent Munoz
    August 6, 2007 at 4:31 am
    got it… in output module > click losslesS
    An OUTPUT MODULE SETTINGS will pop-up.
    at the bottom, check the AUDIO OUTPUT.
    hope this helps to others who has audio problems too.
    by the way, i’m using wav format for the audio.
    cheers!!!
  • Greg Akeson
    July 19, 2008 at 5:59 am
    I don’t get this whole audio thing.
    Sometimes it plays back in ram preview, but never for the entire comp. I gather from these forums that it will only play about 10 or 15 sec of the clip since it fills up the RAM.
    I’ve rendered it two or three times (AVI I believe with the AUDIO OUTPUT checked) but the file is audio-less when played on windows media player. I’ve even tried importing the new file back into Premire Pro but the audio is still missing. What am I doing wrong? Or what should I be doing? Am I expecting too much? The program has crashed several times on me if I try to playback the entire comp. which is only 1 min. with only a few effects and text (Runtime error???) I’m running Windows XP with 2Gb Ram.
    Thanks in advance.
