Activity Forums Blackmagic Design No analog audio input when set to BlackMagic
  • No analog audio input when set to BlackMagic
    Posted by Steve Cohen on July 18, 2007 at 12:00 am
    First forgive me I am not in front of the machine with the problem, so my wording or terms may not be 100% accurate.
    Ok. I have a Blackmagic Multibridge extreme hooked up to a MAC Power PC G5 10.4.9.
    When I have FCP 6.0.1 set to capture with the BlackMagic NTSC – 8 Bit. I get no audio into the system.
    The video is SDI in, but the audio is analog.
    I’m using the Multibridge 6.2 for Mac OS X Universal drivers.
    When I change the easy setup to BackMagic – ProRes I will get my analog audio coming in.
    The control panel in system preferences is set to take analog audio and SDI Video.
    Any suggestion.
    Steve Cohen
    Editor
    O2 Media Inc.
    Andres Posada replied 19 years, 1 month ago 2 Members · 1 Reply
  • Andres Posada
    July 24, 2007 at 4:16 pm
    It seems that in order to be able to capture analog audio, you must feed some kind of analog video also. Try by connecting any video source to the composite in.
