Activity › Forums › Blackmagic Design › No AES/EBU signal coming into ATEM Television studio from Behringer SRC2496 Ultramatch Pro
  • No AES/EBU signal coming into ATEM Television studio from Behringer SRC2496 Ultramatch Pro
    Posted by Aaron Novak on November 10, 2012 at 11:29 pm
    So this set up used to work for me but now its not. No sound seems to be coming into the ATEM from the Behringer. Im going out of the SRC2496 from the RCA digital out to the ATEM AES/EBU BNC connection.
    Settings for the Behringer A/D converter:
    Left-side Source button is set to “Analog”
    Audio input us shown the level indicators.
    The Mode button is set to “A/D & D/A Conv”
    The Format button is set to AES/EBU
    PLL lock light is on (don’t know if that means anything)
    Is there some setting I’m missing on the Behringer or the ATEM? I assume I should see the levels going to the ATEM Software Control Sound tab under the EXT channel…
    Any ideas?
    Lee Stephens replied 12 years, 11 months ago 2 Members · 1 Reply
  • Lee Stephens
    October 10, 2013 at 2:45 pm
    Hi…im having same problem out of the blue… did you fix yours?
