Activity Forums VEGAS Pro No AAC audio using Sony AVC (.mp4) SVP11.
  • No AAC audio using Sony AVC (.mp4) SVP11.
    Posted by Hayden Roberts on November 14, 2011 at 7:13 am
    Been trying and trying for hours but I can’t get any audio while using the Sony AVC option when rendering my videos. I have changed the “format” to .mp4 and then ticked the “Include Audio” option and set the options to: ACC (only options), 44,100Hz, 128,000bps, Stereo. I’ve also made sure the audio track is not muted either.
    As a comparison, the MainConcept AVC/AAC encoder works flawlessly. Get audio and video just as expected.
    Here are the MediaInfo logs comparing the two.
    Sony AVC (using .mp4 format with audio option ticked)
    General
    Complete name : R:Untitled.mp4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42
    File size : 4.28 MiB
    Duration : 3s 437ms
    Overall bit rate : 10.5 Mbps
    Encoded date : UTC 2011-11-14 07:07:48
    Tagged date : UTC 2011-11-14 07:07:48
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 2 frames
    Format settings, GOP : M=2, N=15
    Muxing mode : Container profile=Main@3.1
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 3s 437ms
    Bit rate mode : Variable
    Bit rate : 10.5 Mbps
    Maximum bit rate : 16.0 Mbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 29.970 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.378
    Stream size : 4.28 MiB (100%)
    Language : English
    MainConcept AVC/AAC
    General
    Complete name : R:Untitled2.mp4
    Format : MPEG-4
    Codec ID : mp42
    File size : 4.09 MiB
    Duration : 3s 437ms
    Overall bit rate : 9 975 Kbps
    Encoded date : UTC 2011-11-14 07:09:05
    Tagged date : UTC 2011-11-14 07:09:05
    Video
    Format : AVC
    Format profile : Main@L3.1
    Codec ID : avc1
    Duration : 3s 437ms
    Bit rate : 9 840 Kbps
    Height : 720 pixels
    Standard : NTSC
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.356
    Stream size : 4.03 MiB (99%)
    Language : English
    Audio
    Format : AAC
    Format/Info : Advanced Audio Codec
    Format profile : LC
    Codec ID : 40
    Duration : 3s 437ms
    Bit rate mode : Constant
    Bit rate : 128 Kbps
    Channel(s) : 2 channels
    Channel positions : Front: L R
    Sampling rate : 44.1 KHz
    Compression mode : Lossy
    Stream size : 53.6 KiB (1%)
    Language : English
    As you can see, there is just no audio track being included with the Sony AVC file. I have tried all different sample/bit rate options but I get exactly the same results, no audio track.
    I have Googled my brains out and have yet to find a similar case to this.
    The “easy option” would be just to render to MainConcept but bit rate to bit rate, the Sony AVC delivers a better (more detailed) pictured. This is especially true when it comes to gradients. Sony is much smoother. I really want to get this working.
    Don Bowie replied 14 years, 1 month ago 10 Members · 33 Replies
  • 33 Replies
  • Dave Lozinski
    November 18, 2011 at 5:40 am
    Have you tried just rendering the audio separately? Eg, “mute” all the video tracks?
    IF so what happens?
    If success, unmute the video tracks one by one and see if there’s any in particular causing the issue…
    https://www.davelozinski.com
    https://www.davelozinski.com/DemoReel/
  • Hayden Roberts
    November 18, 2011 at 9:38 am
    If I mute all the video tracks, I do not get an option to render to Sony AVC.
    I have tried multiple video clips, all from different sources. I’ve used, videos from: Fraps, Samsung Galaxy S 1 & 2, iPhone 4 & 4S and my old Sony DVI tape video camera.
    All have no audio even when choosing .mp4 and selecting “include audio”.
    I am using SCP11 x64. Have tried uninstalling and reinstalling. No change. Seriously think it’s a bug in the Sony AVC. Apparently others can render and receive audio. Really annoys me I can’t.
    Regards, Hayden.
  • Dave Lozinski
    November 18, 2011 at 1:22 pm
    Sorry… I wanted you to render it as an audio file such as mp3 to see if it could be rendered.
    You should also try just creating a blank video track. All black. And leave that on with the audio track. See if you can render that black video with audio.
  • Hayden Roberts
    November 18, 2011 at 3:55 pm
    [Dave Lozinski] “Sorry… I wanted you to render it as an audio file such as mp3 to see if it could be rendered.”
    From what you’re asking, it seems to me that you think my source files are the culprit. Let me assure you, they are fine. I can render .mp3 and .ac3 with no problems at all. All the audio is there, just as it should be.
    I have also tried the “empty video track” trick and all I get is a black video with no sound. The audio track is just not there.
    As you can clearly see from my MediaInfo reports, Sony Vegas Pro is not creating any audio tracks, it’s not even trying to. It doesn’t spit out an error. It’s like I’m not even clicking the “include audio” option.
    This has got to be a bug in Vegas. I have tried every single combination of settings, files and who know what else. It’s just not rendering ANY audio, ever.
  • Dave Lozinski
    November 18, 2011 at 5:00 pm
    Hmmm… I doubt it’s a bug in Vegas or everyone would be experiencing the issue of not having any audio while rendering to that format.
    Have you tried reinstalling Vegas from scratch?
  • Hayden Roberts
    November 18, 2011 at 6:19 pm
    [Dave Lozinski] “Have you tried reinstalling Vegas from scratch?”
    Yes, I’ve tried this twice: uninstall, restart Windows, install.
    I have read on this forum a user was having the same issue but changing the audio from 48,000 Hz to 44,100 Hz solved his issue. This doesn’t work for me, nothing does.
    I think it’s worth nothing that this Vegas install was done on a brand new Windows 7 install, so there’s no conflicting programs or messed up registry settings. The first render settings I tried were Sony AVC because I wanted to test the GPU rendering. Been having this bug from the very beginning.
    Maybe not many people try to render in Sony AVC + audio using .mp4? MainConcept AVC + audio (ACC) works perfectly but does not look as good bit for bit. I guess most/all people are happy with MainConcept. Either that or I am experiencing a 1 in a million bug.
  • Bernd Porr
    November 19, 2011 at 11:31 pm
    I’m experiencing exactly the same problem with Sony’s AVC encoder. I’ve switched to MP4 and enabled audio but it’s not in the stream. Seems to be a bug in Vegas. Mainconcept’s encoder works fine. It’s pretty frustrating because the Sony encoder is two times faster than the Mainconcept encoder.
    /Bernd
  • Hayden Roberts
    November 20, 2011 at 12:44 am
    [Bernd Porr] “I’m experiencing exactly the same problem with Sony’s AVC encoder. I’ve switched to MP4 and enabled audio but it’s not in the stream. Seems to be a bug in Vegas. Mainconcept’s encoder works fine. It’s pretty frustrating because the Sony encoder is two times faster than the Mainconcept encoder.
    /Bernd”
    Good to hear I’m not alone. I’m not too fussed about render times but the picture quality is much better using Sony AVC, especially at 1080p.
    Is there a way to mux/join Sony AVC with a separate audio file such as mp3 or ac3 without having to re-render the whole file?
  • Bob Bennett
    November 20, 2011 at 5:12 am
    Could this be the same issue that I’m having with Sony Vegas Pro 11 (Build 425 – Win 7 64bit) and new 1080p files shot on the iPhone 4s? They seem to import OK into a fresh project … images are on the files in Project Media and drag to the timeline to the right length, and images even show up on the video track. But no video plays. Nor does audio … most of the time … although sometimes it will randomly play the audio.
  • Bernd Porr
    November 20, 2011 at 11:41 am
    Hi Hayden,
    you should be able to merge MPEG4 and AAC with MP4Box. It’s a small command line tool which I usually use to make MP4 streamable for flash players. It does all different kinds of MPEG4 manipulations for you. I’ve never merged anything with it but it should work as long as the streams are MPEG4 compliant.
    Here is a recipe how to merge audio and video (taken from https://www.bradchen.com/node/6):
    MP4Box -raw
    MP4Box -add ‘#video’ -add ‘#audio’ [Output Filename]
    You get MP4Box here:
    https://gpac.wp.institut-telecom.fr/mp4box/
    /Bernd
Page 1 of 4
